My sedan install.
My sedan install.
Postby Archetype » Sun Nov 06, 2011 1:07 pm
I've been into car audio since I was old enough to have a car. Every vechile I ve had, I've done an install in. This is my install in my e36 sedan.
Components:
Jvc KD-AHD79 with usb for my Iphone (16gb) and bluetooth adaptor.
MB Quart speakers all around.
2 Mb quart 3 way 6x9 s in the parcel shelf
5 1/4 components in the floor kick panels with 1" titanium tweets in the doors and passive cross overs.
3 12" 2ohm dual voice coil Mb quart with led logo'd cones
Memphis 1000.1 @ 1.33 ohms
Memphis 200 watt running the 6x9s
Optima yellow top
2 farad Cap
The 5 1/4 cant been seen behind the kick panels but you can certainly hear them. The 1"titanium tweets went in the Oem location with no modification.
I wanted to allow the 12's to push air through the armrest (skibag) hole from the trunk. It required some modifications and cutting of the wall between, as well as the sound deadening and seperator in the trunk. I finished the edges with rolled leather to match the interior. Everything was remved from the trunk. The hk amp was removed and bypassed using factory wires to each speaker. 50 square feet of fatmat deadening, applied mostly in the trunk, and parcel shelf. I also covered the trucks bottom and the speaker boxes with the same beige material and sprayed the factory grey sides of the trunk interior with beige carpet dye to match.
The result was a very clean and finished look.
The back of the box (amp rack, etc) is not finished yet. I am going to fab a fiberglass curved, dome like cover piece to give it a show car look.
I still have finishing touches to do obviously, but it is 90% complete. This was a SQ build, not for SPL. It sounds amazing. I had to figure out a lot to make it work and bypass the HK 10 speaker system. If anyone needs advice or help concerning ths, I know... having been there. Hope you liked.
Archetype
Re: My sedan install.
Postby DEFKON99 » Sun Nov 06, 2011 5:12 pm
wowsas!! love the Mb Quart Setup! I actually have 2 10"s in the back with a Hifonics Amp for the subs and Orion amp which i still need to buy speakers for F/R'. Def thinking about a 3 way system for the front..
Postby Archetype » Sun Nov 06, 2011 5:25 pm
DEFKON99 wrote:wowsas!! love the Mb Quart Setup! I actually have 2 10"s in the back with a Hifonics Amp for the subs and Orion amp which i still need to buy speakers for F/R'. Def thinking about a 3 way system for the front..
We both have nearly matching Jvc headunits, and we both run Mb quart subs. You have great taste sir. ;)
Archetype
Postby DEFKON99 » Sun Nov 06, 2011 7:31 pm
Likewise!! 8)
where did you store the Crossovers? Have you Installed the 140A alternator to take over the original 80A yet?
Postby Archetype » Sun Nov 06, 2011 8:06 pm
Likewise!! 8)
Look on the back of the box, left and right of the amp. Thats the cross overs. :)
I ve looked for info on upgrading to a 140 but I m not sure where to get the brackets? Is there a bolt on? Fill me in on that upgrade as I need it, even with a yellow top and cap.
Archetype
Postby DEFKON99 » Mon Nov 07, 2011 9:10 am
We both have nearly matching Jvc headunits, and we both run Mb quart subs. You have great taste sir. ;)[/quote]
Likewise!! 8)
where did you store the Crossovers? Have you Installed the 140A alternator to take over the original 80A yet?[/quote]
I ve looked for info on upgrading to a 140 but I m not sure where to get the brackets? Is there a bolt on? Fill me in on that upgrade as I need it, even with a yellow top and cap.[/quote]
There is no special Parts It Bolts right up its an Original BMW part some if your current is alternator is bosch then your good but if its valeo you'll have to put that pulley on the Bosch.
check out the difference 140 on left 80 on right
they are found in these
1991-1992 E34 5 Series 525i (with 24 valve M50 engine)
1992-1995 E36 3 Series 6 cylinder - 325i, 325is
1996-1998 E36 3 Series 6 cylinder - 328i, 328is, 323is
1995-1999 E36 M3 all, including M3 3.0 liter and M3 3.2 liter
1998-2000 MZ3 M Roadster (with S52 engine)
1999-2000 MZ3 M Coupe (with S52 engine)
Postby JFM325is » Mon Nov 07, 2011 12:17 pm
This is siiiccckk
Postby Archetype » Mon Nov 07, 2011 12:19 pm
And this is the same for all e36's?. M3 alt's fit 323 etc? Niiice, this on my to do list... SOOON.
Archetype
Postby JFM325is » Mon Nov 07, 2011 12:20 pm
This is siiiccckk
Postby Archetype » Mon Nov 07, 2011 12:36 pm
JFM325is wrote:This is siiiccckk
:) Thanx man.
Archetype
