M52 TT S2 soon to run around the streets of Vegas!
Postby Gabe1103 » Sun Aug 10, 2008 8:20 pm
Hi, saw this website just yesterday and reading through the FI threads I find the people here are a lot more approachable and 'real' compared to the peeps over at BFC FI forum.
just want to share that i am waiting for my TT S2 kit to arrive this week and will have some questions to ask about going boost... i haven't posted this in the BFC FI forums since i'm a newb to boosting my M52 and I don't want to get the hostility treatment they provide to newbies like myself :evil:
boost on!
thanks!
Gabe1103
Re: M52 TT S2 soon to run around the streets of Vegas!
Postby fcvapor05 » Sun Aug 10, 2008 8:25 pm
Sick. let us know about your progress!
There are only 3 real sports in this world: bull fighting, mountain climbing, and motor racing. The rest are just games. -Ernest Hemingway
fcvapor05
Postby Gabe1103 » Sun Aug 10, 2008 8:32 pm
shopping for an AFR... should i go AEM UEGO, PLX, or Innovate?
$220 for AEM UEGO is a damn good price though!
Gabe1103
Postby fcvapor05 » Sun Aug 10, 2008 8:40 pm
Innovate or PLX. AEM is cheap for a reason- it doesn't use a real lab-grade sensor and is much less accurate.
fcvapor05
Postby Gabe1103 » Mon Aug 11, 2008 5:15 pm
ok... i might just go with PLX...
also, shopping for a water-meth kit... is Snow Performance the 'ONLY' way to go?
Gabe1103
Postby fcvapor05 » Mon Aug 11, 2008 7:42 pm
A sells a kit too i think.
fcvapor05
Postby Caligula » Tue Aug 12, 2008 2:31 am
Can someone explain meth and water injection for me? What is is used for and what are its benefits?
Postby inthecrosshairs » Tue Aug 12, 2008 7:43 am
Meth CAN add power. Tune your car to the bleeding edge of safe vs detonation on street gas, add water or meth and your back in the safe zone, it increases octane, not power, so you can run more timing, or be safer at the current timing (not usually unnecessary). It also cools the intake charge considerably, so it helps on heat soaked cars.
The most basic explanation is it increases det threshold through increasing octane, decreasing temps. Allows more safety with more timing. CAN make more power, not always will.
inthecrosshairs
Postby fcvapor05 » Tue Aug 12, 2008 2:16 pm
Thats almost right. Meth injection and water injection work slightly differently. Both work by increasing the knock threshold- methanol injection actually works by increasing the knock resistance of the A/F mix. Water cools the intake charge and also works to absorb some combustion heat during the power stroke, which increases the knock limit for the next cycle.
fcvapor05
Postby Gabe1103 » Tue Aug 12, 2008 9:19 pm
ok... now i'm really confused even more! haha!
Gabe1103
Postby fcvapor05 » Tue Aug 12, 2008 9:24 pm
What are you confused about?
fcvapor05
Postby Proctor750 » Fri Aug 15, 2008 8:48 am
Meth inj is like over clocking a computer.
Is the PLX (Aem in general) really that innacurate? I also need wideband stat, and I was looking at a PLX. What would be a better bang for the buck?
87' 528E 89' 750il
89' 750il 93' 318is
92 535i E34 M5 (Sold :( )
Proctor750
Postby fcvapor05 » Fri Aug 15, 2008 9:00 am
Proctor750 wrote:Meth inj is like over clocking a computer.
PLX and AEM are not the same. The PLX is made by NGK. AEM's A/F meter is called the 'AEM UEGO II' or something.
The PLX or Innovate units are much better than the AEM. You can't get around using a lab-grade sensor- it is the only way to go. AEM doesnt, NGK and Innovate do.
fcvapor05
Postby st3althbeam328i » Mon Aug 18, 2008 8:23 pm
standalone is definitely the way to go unless your a laptop tuner these days. What turbo kit did you end up going with? did you piece it or was it a full kit?
4/96 328i Sport Saloon OBD1 AlpinawiessIII My Build Blog! http://mbuild.blogspot.com/
st3althbeam328i
1996 BMW
Postby BLAZNM3 » Thu Nov 03, 2011 9:48 am
Pic update?
BLAZNM3
1999 Leopard
