For All the VF enginnering Supercharged e36's!!! Help
Postby dakare36m3 » Sat Apr 23, 2011 11:45 am
My question to all is have you had any problems trying to fit the supplied intake with the kit cause no matter which way i twist the charge pipe and intake i cant seem to fit it on at all. I built myself a custom intake but i can fit the pcv hose nor the blow off valve b/c there is no ports for it, do you think this would affect anything and my plan is to put a breather filter on the end of the pcv hose leeme know asap any thoughts or ideas. that would be helpful and appreciated
dakare36m3
1998 Leopard
Re: For All the VF enginnering Supercharged e36's!!! Help
Postby DEFKON99 » Sat Apr 23, 2011 4:13 pm
Pics!!!
Postby dakare36m3 » Tue Apr 26, 2011 9:41 am
i will try and take some soon
dakare36m3
1998 Leopard
Postby dakare36m3 » Wed Apr 27, 2011 10:06 am
Another question i have is, where would a tap a boost source for my boost guage people say the small vacum line that goes under the inake manifold and some people say the vacum hose that goes from the top of the intake manifold to the brake booster? Idk which one to do any suggestions.
dakare36m3
1998 Leopard
Postby DEFKON99 » Wed Apr 27, 2011 5:54 pm
dakare36m3 wrote:Another question i have is, where would a tap a boost source for my boost guage people say the small vacum line that goes under the inake manifold and some people say the vacum hose that goes from the top of the intake manifold to the brake booster? Idk which one to do any suggestions.
best place for accurate reading is at the brake booster line going to the manifold. Install a T at that area. Here is the T fitting
http://www.racersmarket.net/index.php?p ... &Itemid=93
Postby dakare36m3 » Fri Apr 29, 2011 10:05 am
Thank you very much for the helpful information. What would happen if i were to use a plastic T? just out of curiosity
dakare36m3
1998 Leopard
Postby Caligula » Fri Apr 29, 2011 11:31 am
I just have a rule to not use plastic parts when theres a metal one available. If not from the brake booster, the EVAP port on the bottom of the throttle body works well.
Postby dakare36m3 » Fri Apr 29, 2011 2:42 pm
Thanks and one last question where can i get a nice boost gauge that lights up amber that matches the gauge cluster color for my car i was thinking about a glow shift one, do you think they are good ones? But i wish defi made there gauges also in orange so it can match.
dakare36m3
1998 Leopard
Postby DEFKON99 » Fri Apr 29, 2011 6:02 pm
dakare36m3 wrote:Thanks and one last question where can i get a nice boost gauge that lights up amber that matches the gauge cluster color for my car i was thinking about a glow shift one, do you think they are good ones? But i wish defi made there gauges also in orange so it can match.
heres a few to choose from
http://www.horsepowerfreaks.com/sale/af ... ost_Gauges
Postby dakare36m3 » Fri Apr 29, 2011 7:00 pm
thank you for all the help
dakare36m3
1998 Leopard
Postby dakare36m3 » Thu May 12, 2011 7:58 am
Some way some how i go the intake to fit its wierd how the kit didnt come with a coupler to fit onto the supercharger but i bought a 4 inch one and made eveything fit was quite a struggle but i got it and i got the boost guage in mounted on the a pillar with amber orange color looks good. Didnt really want it on the bottom by the sunglass panel b/c i wouldnt be able to see it when i need to. Thanks
dakare36m3
1998 Leopard
Postby DEFKON99 » Thu May 12, 2011 1:28 pm
dakare36m3 wrote:Some way some how i go the intake to fit its wierd how the kit didnt come with a coupler to fit onto the supercharger but i bought a 4 inch one and made eveything fit was quite a struggle but i got it and i got the boost guage in mounted on the a pillar with amber orange color looks good. Didnt really want it on the bottom by the sunglass panel b/c i wouldnt be able to see it when i need to. Thanks
nice pic of how you mounted it and the end result?
