Number nine
Number nine
Postby ForcedFirebird » Thu Jul 14, 2011 12:48 pm
Hello all,
New to this forum and just gathered all the parts to build a 325i turbo kit.
Weld els, pipe, Holset hx35, designed a simple flange and had the local water jet cut it, ebay intercooler and have a bunch of pipe, metal, couplers etc to do the job.
Trying to decide between top and bottom mount and any input/pic/links/ideas would greatly be appreciated.
The driver said A/C is not necessary, but if possible I would like to see it stay.
So far I am looking at making a custom passenger side motor mount and putting the Holset just under #4,5,6 exhaust ports and squeezing the charge pipes around everything, but ther's a couple A/C lines in the way.
OR
Top mount by relocating the washer tank and having the turbo in front of the inner fender/over #1,2,3 exhaust ports. Eliminating the dryer and running the charge pipes through behind the headlight.
The Holset is a rather large case, down pipe routing would be easier in the bottom mount scenario, not sure where it could be routed easily with a top mount.
Thanks for sharing,
John
ForcedFirebird
Re: Number nine
Postby ForcedFirebird » Thu Jul 14, 2011 2:03 pm
Got the front of the car pulled apart so far and the ebay intercooler doesn't fit between the headlights. Had a Volvo I/C sitting on a shelf for a rainy day. One could only hope it was raining, heat index of 105* and 60% humidity, shop is roasting :(
ForcedFirebird
Re: Number nine
Postby ForcedFirebird » Thu Jul 14, 2011 3:53 pm
Love the fitment with the bumper back on and all. Stealth :)
Now that it's all fit in, gotta make some brackets...
ForcedFirebird
Re: Number nine
Postby DEFKON99 » Thu Jul 14, 2011 3:54 pm
whaa how big is the Intercooler? Pics?
Re: Number nine
Postby ForcedFirebird » Thu Jul 14, 2011 3:59 pm
It's a standard Volvo inter-cooler. People have gotten more power from them than we are looking for :)
I will take some pics tomorrow when the mounting brackets are finished up.
ForcedFirebird
Re: Number nine
Postby ForcedFirebird » Fri Jul 15, 2011 1:41 pm
Inter-cooler...
and some brackets made of steel strips...
ForcedFirebird
Re: Number nine
Postby ForcedFirebird » Fri Jul 15, 2011 6:15 pm
All bolted back up. Stock electric fan in, condenser still in, this would even fit behind a non-M3 bumper :)
I/C to TB pipe is done, just needs a coat of paint...
ForcedFirebird
Re: Number nine
Postby 4banger » Mon Jul 18, 2011 7:07 pm
looking good!
Re: Number nine
Postby ForcedFirebird » Thu Jul 21, 2011 7:09 pm
Not much has happened on hardware except blasting and painting the fabricated parts, but we caught a grasp of the 413dme, and fine tuned it with the stock injectors. He was actually surprised at the increase just by tweaking the tables. He dropped off the vr6 swapped MKII Jetta and took the e36, so we will do the 42# injectors and re-tune it N/A before finishing up the hot side at a later date.
We have decided to eliminate the A/C and do a top mount since this isn't the daily (South FL is HOT!) and we came up with a fun exhaust exit.
After knowing what the e30 race car made on the dyno has me excited about doing the basic same setup on a 24v. It maxed 36# injectors at 15psi through the same HX35, the e36 is getting 42's.
Pics are always fun...
Interfacing with the 413
ForcedFirebird
Re: Number nine
Postby st3althbeam328i » Fri Jul 22, 2011 7:30 pm
What program do u use to tune the ECU?
4/96 328i Sport Saloon OBD1 AlpinawiessIII My Build Blog! http://mbuild.blogspot.com/
st3althbeam328i
1996 BMW
Re: Number nine
Postby ForcedFirebird » Fri Jul 22, 2011 7:58 pm
TunerPRO v5
ForcedFirebird
Re: Number nine
Postby st3althbeam328i » Mon Aug 01, 2011 8:09 pm
Thanks for the info! Your build is coming to a great start. Can't wait to see this in motion
st3althbeam328i
1996 BMW
Re: Number nine
Postby JFM325is » Wed Sep 14, 2011 8:05 pm
Can I haz preaz? epic build
Re: Number nine
Postby ForcedFirebird » Thu Sep 15, 2011 12:57 pm
Not going to see it finished :(
The owner pulled the plug and traded the e36 for an e30 and bought an Eclipse GSX for us to tweak.
ForcedFirebird
Re: Number nine
Postby JFM325is » Fri Sep 16, 2011 12:13 am
I use to have an eclipse. Fun car, 2g or 1g?
