good turbo kit for my m50
Postby 60Trim » Thu Sep 22, 2011 8:53 pm
Allright here is the deal. I just purchased my 95 325i and I want to run some boost. Iv already bought my headgaskit and arp head studs an I now have enough funds for a good turbo kit. Whats all out there for my motor/car and whats the best to go with. Lmk thanks
60Trim
1995 Maxima
Re: good turbo kit for my m50
Postby DEFKON99 » Thu Sep 22, 2011 9:59 pm
check out the racers market
Postby JFM325is » Fri Sep 23, 2011 5:30 pm
You could build one. I would actually build your engine abit before turbo.. get an s50 head and some forged pistions and rods then go for a turbo. If you go to bimmerforums theres alot of guys who sell packages. I personally like the top mount headers but everyone has their own style. Also I saw a guy on here that put a volvo intercooler in. It was huge and once you put the car back together it was soooo low key. Im going that route dunno if you like the flash of chrome but I dont lol.
Postby 60Trim » Fri Sep 23, 2011 6:32 pm
Yea I was thinking of building the motor first but I wasn't planing on running that much boost. And if anything does go wrong I would then built the motor but for right now id like to see whats out there for a turbo kit first means I know what to shop for when it comes to internal parts. And yes I seen that post about the intercooler. That thing is huge lol
60Trim
1995 Maxima
Postby JFM325is » Fri Sep 23, 2011 6:57 pm
Yeah man ever since i saw that I have been set on getting one. If you want when I go to the yard I can pull one for you. I am going soon to try and find mine so if I can an extra just let me know and I'll grab it for you. As far as turbo kits are concerned I havent found any.. I havent really been looking that much to begin with cause I just decided to go turbo but like I said bimmerforums have some pretty good shit.
Postby 60Trim » Sat Sep 24, 2011 1:02 am
Ya if I was going to go with the sleeper status id go with that front mount but id rather go with a nice shinny aluminum front mount. I'm going to check out bimmerforums and see what I can come up with
60Trim
1995 Maxima
Postby JFM325is » Sat Sep 24, 2011 2:28 am
http://forums.bimmerforums.com/forum/sh ... ?t=1690518 saw this... kinda expensive but you can take ideas from this and build your own turbo set up at half or 2/3 the cost
Postby 4banger » Sat Sep 24, 2011 10:31 am
Piecing together one may be your best bet.
Postby 60Trim » Sun Sep 25, 2011 12:54 am
That's what I was thinking. I was thinking just buy the ebay kit an just replace the turbo and couplers with the good stuff but well see what happins. Winter for me is right around the corner for me so in going to start my build soon
60Trim
1995 Maxima
Postby JFM325is » Sun Sep 25, 2011 1:44 pm
na dont buy the ebay crap. Everything there blows and its just not worth it. Do a build from ground up!
Postby 4banger » Sun Sep 25, 2011 6:25 pm
60Trim wrote:That's what I was thinking. I was thinking just buy the ebay kit an just replace the turbo and couplers with the good stuff but well see what happins. Winter for me is right around the corner for me so in going to start my build soon
I thought the same thing, but around here you can get an intercooler kit custom built for starting at 400 bucks for a decent size core. and a custom built manifold for about 500. after that the rest of the stuff would need to be replaced from the ebay crap so a kit would be more or less worthless. So i'd start but piecing together stuff, forum whore yourself and keep your eyes open.
6 cylinder manifold
name brand turbo
wastegate
bov (blow off valve)
Injectors?
Fuel pump?
custom downpipe/exhaust
intercooler
some form of engine management
a few things I can think of, also take in to consideration new plugs and wires if you need to go a step colder with the plugs clutch depending on condition of the clutch/ power gain etc etc
Postby 60Trim » Sun Sep 25, 2011 10:00 pm
Thanks for all the info guys ill keep this in consideration
60Trim
1995 Maxima
Postby JFM325is » Mon Sep 26, 2011 1:50 am
Injectors will be needed. I suggest 24lb but people go higher depending on how much boost you want. Fuel pump you can keep but this also depends on how much boost you want to run.
Postby euro2fast4u » Mon Sep 26, 2011 10:38 am
How did I miss this thread. You will need larger then 30# injectors for any boost.
What about management?
Postby JFM325is » Mon Sep 26, 2011 1:57 pm
you think so euro? I thought people were running 6-8psi on 24lbs. Management is needed but I am doing that at a local shop here in Socal so I havent really read up on whats good out there.
