M52b28 Swapped 318is
Ya'll know who you are, with your Jersey shores, your guido haircuts, and your MTV studios. So what if you were some of the first states. Woopdie do. Talk about your E36s here, not which hair gel and which wife beaters you buy.
Postby euro2fast4u » Mon Jan 09, 2012 8:09 pm
Looking to step into an M coupe so the e30 has to go.
1991 318is Brillantrot on Black with 193,xxx miles on the body. Almost every mechanical part has been replaced within the past 2 years
Engine/Drivetrain:
M52b28 with cams
OBD1 manifold and all new OBD1 sensors
TRM OBD1 tune
Raceland Euro m3 headers
Full flowmaster 3” exhaust (high-flow cat, resonator, muffler)
Silicone cold air intake
Heavy duty skidplate with welded in support (plate from a dodge 1500, design similar to peerless severe duty plate)
Fully rebuilt getrag260 from Andrew240z
4.10LSD medium case diff
Large electric fan
Autosolutions Shifter (DSSR, machined selector joint and custom reduction shift lever. All custom ordered and hand-made)
Suspension/Brakes/Wheels
Ground control coilovers 450f/650r
Bilstein Sport dampers
Ground control Camber/Caster plates
EVERY bushing replaced with AKG 75d poly (motor, trans, FCAB, RTAB, rear subframe, diff)
Brembo blanks with Hawk HP+ pads front and rear
Ronal LS 15x7 with 225/50/15 all around
Exterior/interior:
Euro Smilie headlights with DDM 55w 5000k HID’s
Authentic MHW taillights
Black Poineer headunit with iPod connectivity
MB Quart component speakers
Exterior is in pretty good shape but the front fenders have been pulled and never finished (smoothed and repainted)
Normal dings for a car of its age.
Very little rust (small spot under the battery tray as usual)
Interior is in decent shape, however has the infamous cracking of the dash.
Looking for $5,500 or best offer. I need it gone before someone else jumps on the mcoupe, so no reasonable offer refused!
this is for my buddy help him get the m coupe
original thread
http://www.e30tech.com/forum/showthread.php?t=111547
Re: M52b28 Swapped 318is
Postby euro2fast4u » Tue Jan 10, 2012 9:32 am
bump for the m coupe
Postby euro2fast4u » Thu Jan 12, 2012 8:53 am
and its sold thanks for looking
Return to New England
