rear heater not working.
Freezing your butt off in those vaders? Post up in the Heating, Ventilation & A/C Systems (HVAC) forum with your questions. Whether you're braving the cold or rolling naked to keep from dieing of heat exhaustion, e36-tech has you and your 1991-1999 BMW 3 series covered.
Postby cptkirk85 » Tue Nov 01, 2011 1:26 pm
my rear window heater isnt working on my compact...its not the fuse and the light comes on but not demisting...also my air con isnt working..light comes on but not joy.
cheers
cptkirk85
Re: rear heater not working.
Postby JFM325is » Tue Nov 01, 2011 7:42 pm
This should go into the heating, air conditioning, and ventalation section. Can a mod or admin move? As for your question, do you feel anything coming out of your vents? If so is the air just not cold?
Postby Caligula » Wed Nov 02, 2011 5:10 am
Unless theres an issue with your CC module, the problem are not related. What year is this? Check for voltage at the contacts at the rear glass, might have to pop off the rear pillar cover.
Return to Heating, Ventilation, and Air Conditioning
