DIY: M3/S50 Cams into M50
Re: DIY: M3/S50 Cams into M50
Postby BMWMPower » Tue Aug 18, 2009 4:35 pm
thanks, awesome.
anyone figure a way of being able to do it with one person.
some type of tool, that will lock the cams in the right position for cam removal/install?
BMWMPower
Postby Caligula » Tue Aug 18, 2009 4:47 pm
Its called camshaft locking blocks.
Postby AlXz » Wed Jul 14, 2010 3:44 pm
Hello :)
Can this bw done on the m50b25 non-vanos engine too?
What about b20? :)
AlXz
Postby Caligula » Fri Jul 16, 2010 12:07 am
Nope, the the top end uses different camshafts, all the M3 camshafts are made for use with a VANOS unit.
Postby emiliano1 » Tue Aug 16, 2011 9:52 am
Hello, sorry to bother you, the setup with s50 cams is the same as if I put M50 cams?
I live in Argentina and here no one did this modification and I have no one to ask.
Excuse me if it bothers you.
Greetings.
emiliano1
Postby gassy wynd » Tue Mar 27, 2012 9:32 pm
Currently i the process of replacing my head gasket. This DIY somewhat installs confidence in myself. Since I don't have access to the camshaft removal tool, i may have to do it w/out the tool. BTW. I am a noob as far as BMWs but not in trying to figure an alternative way. And the easiest one is, "do some research". Thanks guys.
gassy wynd
Previous
