Turbo Build Begins
Re: Turbo Build Begins
Postby BMWManiac » Thu Dec 11, 2008 6:32 pm
Wait till I get the T67 and new tune done...should be late next week finished.....
1997 Arctic Silver M3
OBD I/TRM setup (*545rwhp/520rwtq @ 23 psi*)
2006 Interlagos Blue Z4M Coupe
Carbon Fiber int, heated seats, NAV
1991 Alpine White 325i
Daily Driver
BMWManiac
1997 Almera
Postby Proctor750 » Sun Dec 14, 2008 11:18 pm
copy cat.
87' 528E 89' 750il
89' 750il 93' 318is
92 535i E34 M5 (Sold :( )
Proctor750
Postby BMWManiac » Mon Dec 15, 2008 9:17 pm
Not really much of a choice at this point....GT40 only comes in T4 or I would have gone that route.
Daily Driver
BMWManiac
1997 Almera
Postby Proctor750 » Wed Dec 17, 2008 1:32 am
Just torch that flange off bitch
87' 528E 89' 750il
89' 750il 93' 318is
Proctor750
Postby BMWManiac » Fri Dec 19, 2008 6:32 pm
Well...apparentely it wasn't a T67 that I bought.....Precision SC62
Daily Driver
BMWManiac
1997 Almera
Postby BMWManiac » Sat Jan 03, 2009 10:40 am
Hayes, keep everyone updated.....
So far, I am awaiting the scavenger pump installed and then a little tweak of the tune....should be back on the road in a week....
Then, I need to take the head off to fix the damn oil leak!
Daily Driver
BMWManiac
1997 Almera
Postby Proctor750 » Mon Jan 05, 2009 10:25 pm
yea apparantly my head warped opposite of normal and was shaped closer to an umbrella before I got it machined. Anyway car runs great but I really just need to data log a dyno sesh and send the info to trm and get my final tune. After that it may be time to cut the fenders in the rear and get those black abs rino type plastic dtm flares that come outward so I can fit some fattys back there. I can't increase from 10 lbs until I get this traction sorted out, loosey goosey @ 100 is nerve wracking. I will video the dyno session and post it up here. Until then it's just chillin in the gayrassh.
87' 528E 89' 750il
89' 750il 93' 318is
Proctor750
Postby DEFKON99 » Mon Jan 05, 2009 10:59 pm
Nice work guys!
Postby BMWManiac » Tue Jan 13, 2009 12:37 pm
When are you hitting the dyno Hayes? You, me, Ethon need to get on it
Daily Driver
BMWManiac
1997 Almera
Postby Proctor750 » Tue Jan 20, 2009 3:06 am
Defkon is invited too. Let's wait until it's a bit warmer, and I'll be in Ireland most of Feb soo march or april. Oh and go ahead and roll your new Z4 M coupe off a cliff for me real fast k thanks /Jealous
87' 528E 89' 750il
89' 750il 93' 318is
Proctor750
Postby BMWManiac » Tue Mar 10, 2009 10:04 pm
So who knows when my car will be done. All I have to take care of now is the damn boost creep and my slight oil leak. I should have just stuck with my AA manifold.....tired of spending money on this damn car!
Daily Driver
BMWManiac
1997 Almera
Postby Proctor750 » Wed Apr 01, 2009 11:03 am
lol
87' 528E 89' 750il
89' 750il 93' 318is
Proctor750
Postby Volfinator » Tue May 05, 2009 9:44 am
Wow. Took some time but you got it done! Nice work! Hoping to see some vids soon
Volfinator
Postby BMWManiac » Sat Jul 18, 2009 6:01 pm
Bumping an old thread....I'm 98% done...should be done by Monday!
Daily Driver
BMWManiac
1997 Almera
Postby Proctor750 » Sat Jul 18, 2009 9:04 pm
My Shit just hit the fan in the mean time.
So after cranking the car to 15lbs and getting new tires the car ran perfect for about a month. Unfortunately because I was running 15lbs (what the tune was set for) My pressurizing the crank case situation hit critical. I blew oil past the valve cover gasket into the ignition coils completely ruining one of them and ran on 5 cylinders on and off. I also started to run a bit more rich due to the lack of combustion in one of the cylinders.
I finally got a morosso racing check valve, and ran my second port from my catch can to the exhaust, then plugged the nipples where the smaller line used to drawl vacuum for the ccv from the ICV. This solves the pressurizing, and I replaced the plugs and cleaned the coilpacks and replaced the one dying one.
BUT WAIT! theres more...
Now the car started to run rich in boost, and after a few days driving its finally to the point where it's sitting in the driveway non drivable because of how rich it is running in every rpm even idle.
All day I have been trouble shooting to no avail. I unplugged the o2 sensor and ran open loop and this fixed the car running too rich as I drove around the block. I parked the car went inside to post on bfc, when back outside, started the car and it ran compeltely rich AGAIN still running open loop. I didn't change anything.
So I pulled out the MAF and cleaned it with MAF cleaner, cranked it up on open loop and still pegging 10AFR's (lowest it can read).
So I figured the MAF was not the issue and maybe it was the o2. I plugged it back in and it STILL PEGS 10AFR! So whether it's open loop (o2 unplugged) or Closed (o2 plugged in) the car is running the exact same RICH!
I've done several pedal stomp tests and was getting 1222 which means the car is running rich. No other codes, other than a 1218 from unplugging the battery, and a 1215 later on from cleaning the MAF, have shown. This rules out everything else such as knock sensors and coolent temp sensor, and air temp sensors ETC.
The only remaining thing I can possibly fathom is that the fuel pressure regulator has gone bad, although its only been in the car for 6 months.
I am so stumped right now I can't even begin to imagine what is causing the car to dump so much fuel. I also can't figure out why when I unplugged to o2 originally to run open loop the car improved greatly, only to fail after shutting the car off for a bit and cranking it back up. Now it doesn't care if it's open or closed loop, or whether the MAF is clean, or anything, it just runs rich no matter what I do. WTF
87' 528E 89' 750il
89' 750il 93' 318is
Proctor750
PreviousNext
