Voltage Display
Voltage Display
Postby BMW03 » Mon Sep 19, 2011 5:21 pm
Just got an e36 and here was my first project.
I need to lower the LED intensity and I may smoke the lens a little so you cant see some of the stuff inside the Volt Meter.
Let me know what you think.
BMW03
1992 Fairlady
Re: Voltage Display
Postby DEFKON99 » Mon Sep 19, 2011 9:20 pm
wow that is once nice piece!! where did you get ?
Re: Voltage Display
Postby Caligula » Tue Sep 20, 2011 3:50 am
Brilliant. DIY writeup? Im sure theres other things you could adapt this too.
Re: Voltage Display
Postby BMW03 » Tue Sep 20, 2011 3:43 pm
It was about $5 on amazon (I can get the link later). I have actually had that for awhile now I looked at it for the e36 and it fit really nice; there wasn't a large amount of cutting required. I currently have it hooked up to the 12V accessory that is run to my cd deck. Therefore it turns on as soon as the car goes into accessory.
Thank you for the compliments; if I get some more time away from school I could do a DIY write-up.
I miss cut a little high so there is a small amount that shows in the front right by the shift boot. I also want to smoke the lens a little and then lower the brightness. I will post more pics when I get that done. Otherwise I am extremely happy with the current results.
BMW03
1992 Fairlady
Re: Voltage Display
Postby 4banger » Tue Sep 20, 2011 4:05 pm
pretty interesting
