e36-tech.com • View topic - Seal size for 320i
Seal size for 320i
When it comes time to change your oil and filters or need some help getting the best mileage on your daily commute, you can always check into our general maintenance forum for assistance with your most common motoring needs. Post up any general tech questions you have for your 1992-1999 BMW 3 series.
Seal size for 320i
Postby Pedro McLopez » Wed Jan 02, 2013 9:49 pm
I am just about to start the job of fixing the Vanos as per Caligular's advice. While I am in there and also doing the water pump, belts etc I thought of doing the seal behind the harmonic balancer on the crank snout. So that I can order and get it before I start the job can anyone tell me the size of the seal. Its a M50 B20 engine. I figure I may as well change it as it may have only done 185000k but it is 20 years old and I would much rather not have to go in again in 3 months or something like that when I have the opportunity to do it the easy way.
Thanks in advance.
Pedro McLopez
Return to General Maintenance & Motoring
