ABS
When it comes time to change your oil and filters or need some help getting the best mileage on your daily commute, you can always check into our general maintenance forum for assistance with your most common motoring needs. Post up any general tech questions you have for your 1992-1999 BMW 3 series.
ABS
Postby warchief1 » Mon Mar 26, 2012 2:28 am
sorry guys , this question might seem a bit dump :):)
but idk where else ill be 100 % sure
i have 316i model 92 with engine model 96 M44 inside...
im not so sure if i have ABS or not...
how can i make sure...thanks alot
warchief1
Re: ABS
Postby Caligula » Mon Mar 26, 2012 4:08 am
Some of the very early E36's, all outside of the U.S., didnt have ABS, you can tell just by looking at the front of the brake master cylinder and looking for the ABS unit. There will also be no wheel speed sensors going into the hubs.
Re: ABS
Postby warchief1 » Tue Mar 27, 2012 7:42 am
thanks so much caligula
but what u mean by wheel speed sensor !!
i do feel the wheel sensor after 80k/h , the wheel sensitivity becomes lower...
brake aint bad its so much better than some latest other models....cause of course its the bavarian masterpiece :getmoney
but did i get the wheel part correctly , or u meant somethin else ?
warchief1
Return to General Maintenance & Motoring
