AC
When it comes time to change your oil and filters or need some help getting the best mileage on your daily commute, you can always check into our general maintenance forum for assistance with your most common motoring needs. Post up any general tech questions you have for your 1992-1999 BMW 3 series.
AC
Postby unrated.virus » Mon Apr 30, 2012 9:30 pm
hi bros , i have 92 316i , i was wondering , do i have AC filter ??
as in later models they have AC filter to clean or change
and if i dont have one , what holds the dirt back ?? like which part i need to clean , since im from egypt , its full of dirt :D:D
:getmoney
thanks alot bros...
unrated.virus
Re: AC
Postby JFM325is » Tue May 01, 2012 11:27 am
You should have a cabin filter. Usually the are located behind the center console.
JFM325is
1994 Fuga
Re: AC
Postby Ant Man » Wed May 02, 2012 2:27 am
how often would they need to be cleaned?
1995 BMW e36 328i M-Sport.
"The Ultimate Maintenance Machine"
Ant Man
Re: AC
Postby unrated.virus » Wed May 02, 2012 5:42 am
Ant Man wrote:how often would they need to be cleaned?
it depends on the city u live , or the road u usually drive...
but anyways why dont you just clean it
when ur doin ur inspection II , its really important for ur AC , its like having a new one..
and when ur filter is way damaged , just buy a new one...
i used to do that on my previous E46...
unrated.virus
Re: AC
Postby unrated.virus » Wed May 02, 2012 5:44 am
JFM325is wrote:You should have a cabin filter. Usually the are located behind the center console.
im sorry bro , but i need to make sure i got this right , which part exactly !!
u mean i have to pull out the dashboard and clean cabin filter !!
unrated.virus
Re: AC
Postby MrSickSense » Wed May 02, 2012 8:50 am
http://bmwfans.info/parts/catalog/
Put your serial number (last 7 of your VIN) in this website and it'll show you
'96 ///M3 Techno Violet 5 spd
"Any car that merely takes you from A to B does not go far enough." - August Horch
MrSickSense
1996 Leopard
Re: AC
Postby DEFKON99 » Wed May 02, 2012 7:45 pm
Edge one looks like that stupid cube you buy to reset the brake pistons on doo doo cars -Proctor750
DEFKON99
1993 BMW 3 Series
Re: AC
Postby Caligula » Fri May 04, 2012 12:51 am
Easiest to remove the glovebox and the panel below it. Its takes as little as 15min after youve done it a few times.
These filters should be replaced every 1-2 years.
Re: AC
Postby unrated.virus » Sun May 06, 2012 8:16 am
thanks caligula , this is really helping , cos i live in egypt and theres really tons of dirt around here.
unrated.virus
Return to General Maintenance & Motoring
