When it comes time to change your oil and filters or need some help getting the best mileage on your daily commute, you can always check into our general maintenance forum for assistance with your most common motoring needs. Post up any general tech questions you have for your 1992-1999 BMW 3 series.
by gr8whiteE36 » Mon May 21, 2012 1:54 pm
I bought my e36 and always noticed the carpet behind the passenger seat is soaked and the driver side front capet where your feet go is wet too but the front carpet on the passenger side is bone dry and the carpet behind the drivers side is bone dry it doesnt make sence to me.
Its not the sunroof i checked all 4 drain holes by pouring water into them and they all pour out of the bottom of the car.
Is there anywhere else water could be getting just the carpet behind the passenger and the front carpet on drivers side wet?
gr8whiteE36
by Adam » Thu May 24, 2012 6:49 pm
I think there's a drain at the firewall that, when clogged, will wet the carpet at the pedals.
- Moderator
by gr8whiteE36 » Fri May 25, 2012 4:54 am
Thanks ill try that
gr8whiteE36
Return to General Maintenance & Motoring
