E36 328i buzzing acceleration
When it comes time to change your oil and filters or need some help getting the best mileage on your daily commute, you can always check into our general maintenance forum for assistance with your most common motoring needs. Post up any general tech questions you have for your 1992-1999 BMW 3 series.
Postby duckhunt » Sat Jun 02, 2012 9:35 am
not quite rattling, or sputtering. I think 'buzzing' is the right word?
-Noise has started the past few days.
-Car has done 140k, very well looked after and perfect apart from this.
-Does NOT make noise if revving engine in neutral whilst static.
-As above, does not *seem* to be coming from vanos.
-Arent able to get under the car at the moment, to check loose exhausts, etc
-Happens at roughly over 3k- only whilst applying throttle, not whilst constant speed/revs.
There is a video, its me gently accelerating into 4th, noise is most prominent after around 30secs due to lower engine note.
Any help would be great on what to check! I have an M50 manifold, etc on the way and wont fit until car
is back to running noise free.
Thanks in advance!
vid: http://youtu.be/P7nDOcSNwSM
duckhunt
Re: E36 328i buzzing acceleration
Postby Ant Man » Sun Jun 03, 2012 4:43 am
that sounds fairly normal.... i could hear something but nothing to unusual...
do you have a factory exhaust system?
1995 BMW e36 328i M-Sport.
"The Ultimate Maintenance Machine"
Ant Man
Postby duckhunt » Sun Jun 03, 2012 7:58 am
yea factory exhaust, someone has suggested the DISA valve. I will check that?
duckhunt
Return to General Maintenance & Motoring
