325is Headlinner
Don't go around looking like a filthy hobo, keep your E36 looking its finest with advice and techniques on bringing out the greatest shine and radiance from your car's paint and upholstery.
325is Headlinner
Postby 94E36OHIO » Sun Mar 14, 2010 2:30 pm
Is it true that you can just use some sort of steamer and roller to fix your headlinner? If so what kind of steamer and roller should I buy?
94E36OHIO
Re: 325is Headlinner
Postby DEFKON99 » Sun Mar 14, 2010 5:47 pm
this is what your referring to,
http://www.bimmerboard.com/forums/posts/649174
Postby 94E36OHIO » Tue Mar 16, 2010 8:07 pm
You the man, thanx for the link
94E36OHIO
Postby Adam » Sun May 09, 2010 2:55 pm
Be sure to let us know how this works out. I know the 318ti's are notorious for sagging headliners, and supposedly the only good way to fix those is to replace them because they're tempermental. It will be good to know if this method works for you.
Return to Detailing & Auto Body Tech
